Eric1971
- May 1, 2019
- 1995 Explorer Eddie Bauer
The last fixed worked for two years, now I have odd behavior again.
When I turn the key to ON (engine off), the display comes on just fine every time: everything on for half a second, blank for half a second, then proper display of temp and compass. However, when I start the engine and power is momentarily cut, the display comes back on with everything lit for about 60 seconds, then everything lit but flickering for 30 more seconds, then the "normal" blank for half a second, followed by proper display.
I tried the original fix, checking the solder points on the resistors and capacitors. Resistors test ok. Capacitors seem ok, though not entirely sure on those. The small cap seems to hold 5V but the two big caps are reading more like 80mV, as if they aren't charging. Still it confuses me that it ALWAYS works fine turning key to ON, but acts up on starting.
I even tried disconnecting the display when properly on for a moment to act like the engine start cutting power, but the display came right back on normally.
Any ideas?
Any ideas?
