Overhead garage door repair - frustration | Ford Explorer Forums - Serious Explorations
Hello all,
I have a pretty typical 4 panel sectional overhead garage door. The motor pulls from the center, the spring is a torsion type, there is one track on each side, and 5 rollers on each side.
Maybe 3 or so months ago the rollers started eating themselves. I didn't notice any changes in the door set up, so I replaced the rollers (standard type). Now again the #1 (not the bottom, the next one up) and the #2 rollers have been destroyed. It looks like the tracks are twisting.
The puzzling thing is this door is 25-30 years old, and I have replaced rollers over the years (I have lived in this house for 7 years).
The springs and operator motor have been replaced. The culprits in my mind are the tracks or the hinges themselves. How would I diagnose the situation?
Any suggestions are welcomed, I am at a loss as to what could be the problem. I feel like if I keep throwing new rollers at it, they will keep getting destroyed. Thanks.
Hello all,
thanks in advance for any help
Pull the emergency release and operate the door manually. It should be relatively easy to lift if the springs are correct and it should move smoothly throughout the travel. Doing it manually gives you a better feel for whats happening and where it might be binding.
I moved this thread to Home Improvement.
Last post was the best answer.
