myerzkid
- August 3, 2010
- Box Elder Montana
- 2004 XLT V6
Ok guys I need some help...
I have an 04 explorer V6 and its acting strange. I live in montana so it gets cold. Coolant was low and the heater wouldn't get hot right away and would only blow hot air while we were driving. I added some coolant and viola problem solved.
Yesterday we get on the road and it was a warm day, comparatively, and we decide to take a little trip to do some shopping. we make it about 60 miles down the road and I just happen to look at the console and it tells me that I am overheating. I pull off and let it cool down. start up again and it says its temperature is in the normal range. I pull out and the heat shoots right back up.
So I turn around and go back to the nearest town after deciding that my Tstat is screwy and it needs replacing. when I get to the nearest station I decide to refill the coolant because alot had been forced out of the overflow tank. It takes and entire gallon of premix without blinking. So I add some straight coolant and alternate distilled water to get it back to a workable level.
No more overheating. Since we are closer to our destination than our origin we press on and the temp stays in the normal range. However once we get back into stop and go driving I noticed that the heater started acting funny again. It'll go cold, then hot, then cold but the vehicle stays in the normal range.
I need some help guys... Is it just the tstat... Its not leaking, I changed the housing last winter... No other fluids in the coolant...
