MunkeyTX
- October 10, 2008
- Deep South Texas
- '04 Explorer EB 2WD 4.0
2004 Ford Explorer 4.0 EB 2wd, Aux Rear AC, Oil Cooler
I've had two random overheat situations over the past two weeks; the first was without any leaks or evidence of a leak, but the second had a tell-tale sign:
Ah-ha! Easy peasy, it's a simple split heater hose! A quick Google/Ford Parts search brought up part number "KH-72 Hose, Tee to Heater Control Valve". I thought I had this problem licked!
So I decide to remove the hose, to verify that it is split...and what do I find?:
Hmm...no splits, and hose looks to be in good condition, nice and supple...ok...so maybe the leak is at the heater control valve nipple that the hose connects to?
Nope, strikeout again. No signs of cracking. WTF??
Now here comes the kicker...that "KH-72 Hose, Tee to Heater Control Valve" is actually molded to the damn tee! I only realized this after I broke the hose away from the tee. Since I already poo'ed-the-bed and yanked one hose off the tee, I went ahead and broke away the other two hoses that were molded to the tee. Now take note: the tee was not leaking as seen by countless other members here...it was perfectly peachy.
At the very least, I'm going to need a new 3/4" tee regardless of what I do, and the dang "KH-72" hose...I'm gonna re-connect everything back up to the tee old-skool style via hose clamps and go from there.
So...can a hose look perfectly good, but still leak out? I truly do hope that my overheat issues were caused by this measly heater hose. The first had absolutely zero signs of leaking anywhere on the engine (including this hose/valve!) I fear that the only reason this hose was leaking is because the system was mighty hot, pressurized, and generally pissed off after the 2nd overheat, and this connection point just happened to be the weakest point in the system. As the pics show, everything looks dandy and nothing is overtly fubar'ed.
So what do y'all think?
