Overly Sensitive gas pedal
rpmgolfs
Location
Kansas
OVERLAND PARK
2020 Explorer Platinum
Anyone find issues with a overly sensitive gas pedal ? I have to be very careful with mine. Put it Sport Mode and you'd better have a lid on that coffee or you'll be wearing it.
  • Like
Reactions: imp
Join the Elite Explorers for $20.
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
themishmosh
NE Ohio
2020 Explorer ST
It's stupid. Way sensitive throttle in Sport to make it seem sporty and fast. I don't even put it in Sport for that reason.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve II
Callsign
VE3
The only time I've noticed it is when driving and slowing down and then just touching the accelerator. That is in 'Normal' mode. I haven't really paid attention if it is the same in 'Conserve (ECO) mode.
ParkM
CA
2020 Aviator Reserve 1
I’ve noticed it sometimes after I have backed up and shifted into Drive. I touch the gas to go forward and I feel like I’m in rocket ship mode for a moment.
/park
cpainter3
Location
Troy MI
Troy MI
2020 Explorer ST
I guess they figured you’d want that sensitivity when in Sport mode. Just put it in Eco and it’s the exact opposite - very docile.
ParkM
CA
Good point and that is something I need to play with. I don’t think I was in sport mode but I have to test again to be sure. Much to learn. Tnx for the tip.
/park
metroplex
Location
Detroit, MI
Detroit, MI
2018 Ford Explorer XLT
In Sport mode, the pedal map ratio is increased meaning the throttle blade is commanded to be open a lot more than normal given the amount of pedal application. Typically Ford's electronic throttle bodies are very laggy, so it might be a good thing.
bjarnold1
Nampa
2020 Explorer XLT
I have noticed that intermittently upon acceleration from a stop the Explorer will jolt or jump forward with the slightest acceleration. Does anyone else have a similar problem?
Shohola
2004 explorer XLT
If its really a 2020 explorer take it back and tell them you want your money. Not off to a good start already.
peterk9
Staff member
Moderator
Callsign
VE3
I believe this has been discussed before referring to a 'touchy' or sensitive gas pedal.
peterk9
Staff member
Moderator
Callsign
VE3
Your thread was merged with this one found using the 'Search' feature.
