therigwelder
- August 18, 2006
- mississippi
- 99 xl
my wife owns a 99 explorer the check engine light has been on for awhile so i pulled the codes .0171 and 0174 system adaptive fuel too lean and too rich what ever that means.i presumed these codes had something to do with the 02 sensor.my understanding is only the sensor nearest the manifold is the primary pcm signal sensor so this was the only sensor ive tested .now for my test results.@cold start up the sensor read .08 millivolts,@operating temp the sensor read 0.12 steady not actively fluctuating between high and low voltage(i think the correct voltage range should be .1 -.09). now if ive got my wires right B+VOLTS= RED/WHITE
HTD GND= LT BLUE/ORANGE
SIGNAL= ORANGE
GND= GREY/LT BLUE
my readings koeo are B+VOLTS- HTD GND = 0 MILLIVOLTS
B+VOLTS - GND=6.40 VOLTS
SIGNAL TO BAT- =38.2 MILLIVOLTS
i think this sensor is bad what do you all think?
SIGNAL= ORANGE
GND= GREY/LT BLUE
