P0174 System too lean (Bank 2)??? | Ford Explorer - Ford Ranger Forums - Serious Explorations
CoachR
CEL came on so I went to autozone and got this reading P014 System too lean (Bank 2), however truck seems to run just fine. I have an 03 Sport trac 4x4, 4.0 SOHC v6. My neighbor and another buddy say to change the O2 sensor. ONly thing is will this fix it. ALso, I see 3 O2 sensors is that how mnay there are on this vehicle, or am I just not seeing on. My truck starts kind of slow and during the winter sometimes would die right after I started it. During the summer it has just been a little slow starting. I have 94K on it so figured I would change the spark plugs. SO my question is will changing the O2 sensor fix the problem, and which sensor do I need to change for Bank 2??
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
Ditto, plus mine was the fuel pressure, check that also(62psi). Welcome,
briwayjones
Manual Master
Location
Maryland, USA
Eldersburg, MD
2000 Ford Explorer XLS
If you've never changed the plugs and wires do that first. They can cause it. If it doesn't help it's probably still more likely that's it's some kind of vacuum leak than a bad O2 sensor.
Welcome to the forum.
