P0303...plug ok - What now? | Ford Explorer - Ford Ranger Forums - Serious Explorations
motor3124
Phoenix
2000 Explorer Eddie Bauer
I recently picked up a 2000 Explorer 4.0 SOHC with 123K miles, was an older mans truck that sat at the family vacation home. I did the usual maintenance including motorcraft plugs, wires as well as the upper & lower intake gaskets since the idle was low and had a vibration. This also fixed the 15-18 % high fuel trim on both banks. I put about 200 miles on it as a daily driver and as I pull in the driveway I get a rough idle / check engine light - P0303. Also bank 2 shows 25% fuel trim while bank 1 is normal???
Things I've tried so far with no change:
Swapped in one of the old plugs
Swapped in an old plug wire
Tried another coil pack I have laying around
Swapped upper and lower intakes with a spare set
Smoke tested for vacuum leaks
What do I check next???
Fix4Dirt
Get a Load O' This Guy!
Los Angeles, CA
1998 XLT 4x4
has many causes including low compression etc etc so mant causes is the 25% idle load etc?
Fix4Dirt
Los Angeles, CA
1998 XLT 4x4
The long term fuel trim for bank 2 is 25% at idle. I'm using Forscan and a laptop for diagnostics.
i dont think mine was like that at idle but its been a while
Runnin'OnEmpty
Southeast USA
2000 Sport
Maybe #3 injector left work early...?
My OHV did the same at about 150K miles,
but I didn't check the fuel trim.
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
cyl 3 misfire
check wiring to the injector since you were just in there
Very likely the injector is clogged or not firing
Run engine, blurp throttle, shut it down, pull plug on #3 is it wet with fuel?
motor3124
Phoenix
Well...did a compression test. Cylinder 3 is at 30 psi. All others at 150. I'll be taking the passenger valve cover off to see what's up. It looks like a ******* to take the head off with the timing chain setup coming from the back on this side if it needs head work.:oops:
Lee's Automotive
Git-R-Done
Alabama
99 Explorer XLT 4.0 SOHC
Yeah not fun bro that sucks good luck
donalds
Location
Stem
Nc
1999 ford explorer sohc
That does suck
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
pull the engine
seriously I would
Do the compression test again to confirm it was not a fluke (I doubt it not with the code corresponding to the cylinder) but we have to check
Then add a capfull of oil and do it again, any increase in psi? (points to rings if it increases, if not points to valves)
Now after you confirm cyl 3 is FUBAR its time to pull the engine, messing with removing the head on the passenger side on a SOCH is not going to happen, tear down maybe, but repair no way jose...........quicker and easier to lift the engine out
C420sailor
Long Island, NY
98 XLT SOHC, 99 EB 5.0L
Then once you pull it, it may just be easier to replace with a low mileage used motor
It’s a rabbit hole for sure
