pzy3339
- November 29, 2012
- columbus ohio
- 2006, 4x4 Limited 4.6
Car was running fine, pulled into my driveway and shut it down. Started the car again about 20 minutes later and it was idling pretty rough, also rough on acceleration. Check engine light came on about 3 minutes down the road and it gave a p0304 code when I got home.
Coil pack is my first guess. However, the truck does have an exhaust leak and I have noticed it idles a bit rough on startup and as the leak tightens up with the heat the engine would run smoother. So I am curious if perhaps that could cause this issue? Would the engine throw a misfire code if the issue was the O2 sensor getting a faulty reading?
Thoughts?
Thoughts?
