P0340 Help | Ford Explorer Forums - Serious Explorations
P0340 Help
Shapechanger
Omaha, NE
1985, 1987 Bronco II
Have a 1999 Ex with the 5.0. It had a P0340 code, so i replaced the alternator and replaced the camshaft synchronizer with a Motorcraft unit. It runs good, drives ok (transmission is going out, no plan on fixing it as i am scrapping it). All seemed to be ok, but the P0340 is back. I am getting 14.5-14.6 volts at the battery and the alternator. Not sure what else to chekc/replace.
Any input would be greatly appreciated.
Ok so i may have figured out where the P0340 is coming from. When I bought the ex, i bought it from my brothers girlfriends little sister, and when u bought it she had lost the keys, and with it having PATS i had no way to start it. So i swapped out the computer and all PATS modules with ones i am pretty sure came from a 98. The 98 has a different sensor from the 99, so the comp is probably looking for a different signal than what is being sent.
So, am i correct in thinking that this is whats causing my P0340 code?
Stock comps p# - XL2F-12A650-PB
New comp i swapped in p# - F87F-12A650-AVB
