H.Flores
- November 24, 2005
- Meriden, CT
- 96 Limited AWD 5.0
Hi guys i know this has been covered but did a search and can't find anything that helps I own a 96 explorer limited AWD with the 5.0 engine. I keep getting the insufficient EGR flow code (also showed misfire on number 8 cylinder plug was bad, replaced it and no more mis-fire)on my truck and I removed the EGR Valve and cleaned it but still getting the code, I really do not want to spend the 140.00 replacing the EGR valve if that is not the problem- most posts point to the DEPF sensor but, my truck does not have one
any ideas on trouble shooting will be really helpful
thanks in advanced Harry
