aybanez
- March 1, 2012
- Phoenix, AZ
- 2000 Ford Explorer Sport
got a p0440 error which says:
With a P0440 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
Remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back.
Inspect the EVAP system for cuts/holes in tubes/hoses
Inspect for damaged or disconnected hoses around the Evap purge solenoid
Check and/or replace the sensor
Check and/or replace the purge valve
Have a professional use a smoke machine to detect leaks
so short of going to a pro anyone know where the Evap purge solenoid is? the sensor? or purge valve?
any help appreciated
