86capriasc
- September 19, 2009
- Wisconsin
- 1998 Explorer XLT
P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
I now get this code after swapping trans in the wife's 98 Explorer sohc.
What does it exactly mean? The truck runs and drives just fine but it get this code. Before the swap I had a code P0706 Transmission Range Sensor Circuit Range/Performance. I did not use the same sensor from the bad trans I just used the one that came on the replacement.
What should I look for? I have cleared the codes and she will be driving to work with it tonight. I will see if it comes back up. Or should she not drive it until I get it figured out?
