So i have an explorer that has been very well cared for and treated well all of its life. I have fortunately never had to replace a single part in the trans, which from what I have read, is a miracle. I have 160K miles on it and now I am getting the p0741 code, and my converter is not locking properly. It locks from time to time at lower speeds, but almost always will lock if I reset the PCM (shut of engine) and then head down the freeway ramp briskly, but not WOT by any means. When it does lock, it is solid and smooth. It doenst slip. If it unlocks on the freeway, most times it will not relock and then blinking O/D light starts.
I have noticed that there is minor shift flare from 3-4, and in general the shifts just aren't as good as they use to be but they are not alarming or anything.
I have had the fluid flushed (yes, the dialysis type flush on the machine at Ford) 4 times prior to this, roughly every 40K - which is about 4 times more than most people i have read about on this forum who are asking about the same problem. I did take it to an AAMCO reciently where they scanned my code and pulled the pan, changed the fluid and filter. This did not net any improvement. I was able to get under my vehicle and look at the fluid and the pan - which to my delight was clean, although the fluid was dark. (I recently moved to Florida from Michigan and had my Explorer heavily loaded, but no trailer or anything, the vehicle was hot as h3LL in the southern stretch of the trip). There was essentially no debris in the pan, which for 160K miles is a good sign that the friction material is not worn out and that my fluid flushes were not in vain.
So here is where I am at: I have the intermittent converter lockup which I intend to resolve. I have done every bit of work on my vehicle to this point, and I have been working on my cars for 15 years now, so I am not going to just throw money at some shop now. I have searched a ton on this forum and really not found anything that has been a definitive fix for this, so I am to this point which is unfortunately just changing parts.
Should I -
Replace the Valve body with a remanufactured unit first? I know its a wear item, so it should help regardless.
If this doesnt fix it, should I replace the solenoid pack? I understand the solenoids are wear items also.
Should I just replace the pack along with the Valve Body?
I have a basic understanding of how the converter works - there is a hydraulically controlled wet clutch pack. Since when it is engaged, it is a good lockup, I have a hard time thinking the converter is bad - unless someone comes back and says that this is most likely the problem. I have read lots of posts about converters being replaced and the problem persisting.
I am confident I can change all of these myself, although I will need assistance from a friend to pull the trans/converter if that is what has to be done.
I know a reman trans is about $1300 for a 'carry out', but I have a hard time justifying that just yet. If that is really the best route, I guess i will have to consider that, but since I had a clean pan and really a good trans prior to this, I have to believe that I just need to fix the wear items - wear items that it sounds like I have gotten far longer than average life out of.
Thanks in advance for all advice.
Ed
Should I -
Ed
