f1fan
- January 15, 2022
- Goodyear, Az
- 2006 Explorer limited 4.6
Ok guys first post here. I have searched the forums for this but I have not really seen anything with the same issues. I have a 2006 4.6 3v limited and the issue is a only at idle when clod or hot. I get a small stumble of the idle and the P2195 lean o2 sensor bank 1 code pops up. I have changed all coils and spark plugs with motorcraft parts. I have smoke tested for vacuum leaks, checked all vacuum lines for leaks as well as cleaned throttle body and MAF. I inspected for possible electrical wire damage and can’t find anything. The truck has 88,000 miles on it. When normal diving there is no issue and I am dumbfounded. Any help would be great, thanks in advance!
