ericsauvage08
- August 1, 2011
- Omaha, NE
- 04 XLT, 14 Limited
Hello, My 04 XLT (207k mi) has been throwing the P2270 (O2 Sensor Signal Stuck Lean Bank1 Sensor2) for a while. I've replaced all the O2 sensors, the downstream ones twice. I also replaced the PCV (PCV hose looked fine, connections seemed tight) and the Fuel Injection Pressure Sensor. It also has newer plugs, wires, and coil. MAF has been replaced within the last 3 years and still looks ok. Air filter is clean and everything associated with the air intake appears tight. IAT sensor is also newer. Throttle body is clean. Thinking about replacing the EGR (it's original, and rusty) but I am not sure the EGR is directly related to this code. I have read that it could be the cat or an exhaust leak, but am hoping someone has better news for me. Anyone have any ideas? The gas mileage is noticeably worse these days. Thanks!
The following is a readout from the torque app while idling:
Fuel Status = 0 byte
Engine Load = 92.549 %
Engine Coolant Temperature = 195.8 °F
Fuel Trim Bank 1 Short Term = 15.625 %
Fuel Trim Bank 1 Long Term = 7.031 %
Fuel Trim Bank 2 Short Term = 0 %
Fuel Trim Bank 2 Long Term = 10.938 %
Intake Manifold Pressure = 13.779 psi
Engine RPM = 1,963.75 rpm
Speed (OBD) = 61.516 mph
Timing Advance = 16 °
Intake Air Temperature = 87.8 °F
Mass Air Flow Rate = 48.2 g/s
Throttle Position(Manifold) = 34.118 %
Fuel trim bank 1 sensor 1 = 0 %
Fuel trim bank 2 sensor 1 = 0 %
Run time since engine start = 624 s
Fuel Rail Pressure (relative to manifold vacuum) = 38.186 psi
EGR Commanded = 0 %
EGR Error = 0 %
Fuel Level (From Engine ECU) = 34.51 %
Distance travelled since codes cleared = 380.901 miles
Evap System Vapour Pressure = -171.75 Pa
Barometric pressure (from vehicle) = 14.504 psi
Catalyst Temperature (Bank 1,Sensor 1) = 1,346 °F
Catalyst Temperature (Bank 2,Sensor 1) = 1,346 °F
PID: 41 = 0
Voltage (Control Module) = 13.355 V
Engine Load(Absolute) = 60.784 %
Commanded Equivalence Ratio(lambda) = 1
Relative Throttle Position = 20.784 %
Ambient air temp = 73.4 °F
Absolute Throttle Position B = 54.51 %
Accelerator PedalPosition D = 38.039 %
Accelerator PedalPosition E = 43.529 %
Accelerator PedalPosition F = 32.549 %
EGR Commanded = 0 %
EGR Error = 0 %
PID: 41 = 0
