Panel Blend Switch | Ford Explorer Forums - Serious Explorations
Panel Blend Switch
iteotwawki
Beaumont, CA
'92 XLT 4X4
OK the question, when I have the blend switch set to Panel, I can still feel significant air flow at my feet.
The switch works. If I move it to Defrost, I can hear the doors close and feel the air flow above the dash or if I move it to floor, the air will only blow on the floor, but If I set the switch to Panel, I still get air flow down by my feet.
Any ideas?
Mr. Moderator, can you please move this to the Under the hood forum, it's a little quiet here? :D I should have put it there in the first place.
I would start by removing the control and seeing if there is anything obvious. Then make sure the airbox doors etc are working right.
Thanks for the tip.
:( I was hoping to avoid that, however that's probably the first step. I'll be digging into the dash anyways as I have to deal with a pesky tachometer that reads inaccurately.
Did you find anything? I am having this same issue.
