tesla4all
- September 9, 2020
- Statesboro
- 2004 Eddie Bauer
Hi folks.. have read thru all seemingly applicable threads and pulled fuses for rear wiper... radio/DVD.. Now, the CD player cycles several times before finally giving up and quitting. When I close the car doors my amp draw runs .52 for about 10 seconds then drops to .42 where it remains. I have dialed down the interior lights to OFF... Courtesy lights completely off. The only difference I have noticed is when I remove the fuse for the PAT system when closing the door the voltage remains at .40..... I've not gone through the entire process of pulling each and every fuse yet. Update... went through pulling power fuses this morning and found the draw on fuse 15... a 15A that according to the users manual provides power to "Memory (PCM/DEATC/Cluster), Courtesy lamps" My next move is to check all courtesy lamp bulbs for failure. If you have had a similar problem that you've solved please let me know,.. I'll update as I go.. Thanks in advance for your input...
