anderson83
- September 16, 2016
- Izium, Kharkovskay oblast, Ukraine
- 1999 Ford Explorer
Good afternoon!
I have a 1999 Ford Explorer 4.0 sohc. The problem with the marker / parking lights on the right side - they do not work. Check fuse # 11 (15a), could not find the switch - off in the four boxes all relays, but the position / parking lights on the left side continued to burn. Wiring is working properly. Wiring check tester: there is not closure, wire "rings" - break is not.Wiring I was calling by tested (multimeter). I connected negative wire by multimetr to the ground of the car and positive wire to the contact of the park lamps. The park lamps themeself is working. I was the park lamps checked by connect to the working contact of the park lamps on left side of car. Disables the fuse - the park lamp does not work, disable relay - running on left side park lamps, right unchanged. If the relay is off, turn off the fuse, the turn lamps start to burn continuously on both sides. Also check short to ground, the tester indicates zero. The battery is not discharged. I spent a replacement relay - unchanged. Additional devices in the car, do not connect, everything is factory. I'm understand as I have an open circuit in the wiring - because, if disable park lamps relay - parks lamps on left side of the car stay included. This is indicate as had power bypassing park lamps relay, but in conformity with wiring digramm (http://portal-diagnostov.ru/index.p...remontu/ford/explorer/2070-1999-ford-explorer) how I understand, power from #11 (15amp) fuse go in to headlamp relay, then power from headlamp relay go in park lamps relay (pin 5, then from pin5 go in pin 1, then power go in park lams from pin 3 park lamps relay), then power go in to dimmer relay from park lamps relay, and then power go in to main light switch from dimmer relay. And, how I understand, power go in front/rear turn/park lamps and stop lamps after park lamps relay, ground has body car (fender, quarter panel).
At first I thought as power go from headlamp relay to park lamps (bypassing park lamps relay), but if disable headlamp relay - parks lamps on left side of the car stay included. The only thing as disabled park lamps is #11 (15amp) fuse. I think, I have problem with main light switch ore dimmer relay ore connectors wiring, because in conformity with wiring digramm: when turn on position park light of main light switch - power go to park lamps relay, then power from relay go to connectors to the lamps. But I don't understand: if disabled all relays (in junction box, in relay module, etc.) why park lamps on left side of the car stay uncluded?
Please, do not know what to do. Thank you in advance!
