mals
- February 26, 2004
- st. louis, missouri
- '00 explorer
I am replacing the parking brakes on my 01 Explorer. I noticed that the parking brakes can rotate about 5 degrees left or right with the hinge point being at the 12 oclock position where the pads set in the notch. Is this normal?
Also I was able to reinstall the upper spring with very little effort, just a slight pull and the spring popped right into the pads. Everthing I have read says these springs are extremely difficult to install. The adjuster and lower spring are in place. I have not had a chance to try out the paqrking brake because of a brake cable will not release so I figrue I will need to replace that also. The pads are from Advanced Auto it that matters. Any thoughts.
Mals
Mals
