sls33
- August 17, 2006
- Baltimore, Maryland
1997 Ford Explorer. I recently replaced the rear parking brake shoes, rear brake pads, and rear rotors. The parking brake has never really worked. When I replaced everything I had a hard time getting the rotors back on, but eventually got them on, although it was VERY tight putting the rotors over the new parking brake assembly.
Now, when the truck is in drive, the brakes smell as if they're burning almost as if the parking brake is rubbing to close to the inside of the rotors. Even weirder is that after replacing the above, the parking brake still doesn't work (when the parking brake is depressed and the truck is put in drive, the truck still moves??).
Does anyone have any ideas what could be the problem? Also, I'm sure the rotor will be a pain to remove, so outside of beating the thing to death, any good ideas about how to remove it?
Thanks!
Thanks!
