Parking Brake Shoe Springs - Cant get them re-attached | Ford Explorer - Ford Ranger Forums - Serious Explorations
Gatorblazer
Moody, AL
02 Explorer, 09 Mazda 5
Any tips on getting the springs back in? I tried screw drivers, brake spring tools, witchcraft, etc... nothing works. Am I missing a trick?
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
bigmiketino
NJ
2017 Explorer Sport
I used a set of needle nose vise grips to muscle them back on..
Gatorblazer
Moody, AL
Will try that. not sure how I missed that link when searching. Thanks
biswrest
Bismarck, ND
2003 Mercury Mountaineer
Did you get it? I used a screwdriver and used it like a lever then once I had it stretched far enough I was able to push down on the top with a needle nose.
gtbutler
Conway, SC
2005 Explorer, Limited V8
Advance auto has a brake spring tool that uses the same principles as the awl. T handle with a hook at the other end.
A little cussing. Some skinned knuckles (because that damned spring lets loose a micrometer short of being in, only nice thing is since the spring is somewhat covered when it lets loose it falls to the ground instead of being shot 150 feet into the neighbors yard).
Relax and take a deep breath and I bet that spring goes in the next time you try.
Jeez I hate drum brakes! :D
