02XLS
- August 30, 2007
- The 51st state South Jersey
- 02 XLS
2002 Explorer XLS....Passenger side vents are not as cold with a/c on.
(manual a/c unit) Tested charge and it shows 40 vs 45 being a full charge. Could my gauge be wrong? The rear passenger air vents feel real cold as well as the driver side middle & side vents but the front pass. middle and pass. side vent does not feel as cold nor as strong blowing. The air is not warm as stated in other threads but just not as cold. Do I need a charge? Is it the blend actuator? If so, where is the passenger blend actuator located or is there only one actuator for the whole setup? Location? Searched through the forum and only found driver's side info. HELP!!!
Thx., 02XLS
Thx., 02XLS
