Dwelves02XLT
- March 3, 2011
- NORCAL
- 05 Eddie Bauer 4WD
Need some feedback guys, have a 2005 EB, which I was changing the rotors and pads up front last weekend. Prior to that, the vehicle sat lifted on jack stands for a week with the doors locked and factory alarm on, wheels, calipers, rotors off. Normally I never disconnect the battery when performing such function, but this time, for some apparent reason, I did not unlock the doors to disable the alarm and during the process of changing the brakes and rotors, I accidentally bumped the knuckle with a spare rim, I had underneath for added protection. For some odd ball reason it caused the horn to go off. I panicked of course and grabbed key fob to stop it, which nothing happen, the thing is the horn wasnt consistent, but sparatic. Couldnt tell if the lights were flashing or not given it was 7 am in the morning and my first thought was to silence the damn thing so I wouldnt wake the neighbors.
I disconnected the battery of course which silenced it. Continue to proceed with changing of rotors and pads and when I did, went ahead and reconnected the battery. As soon as I did the horn continue to go off sparatic again. So I disconnected it, fast forward a few hours, I pull the horn relay fuse in the engine bay and reconnect battery. The thing now is, when I open the driver side door, I hear sparatic door chime sound along with a clicking sound coming from the dash. On top of that, the gauges are flickering as well with slight movement along with the stereo lights diming in and out. I try starting it, which the vehicle seems to be getting power, but is not turning over.
I disconnect the battery again and did further searching, this time underneath the dash, in which I came across this fisaco of wiring:
This is some audiovox which seems to be a bypass for a remote start
This as well under the hood
Is it safe to say that the remote start/aftermarket alarm is preventing the vehicle from starting and has malfunction in some sort of fashion?
***Also as of today, I had the current battery taken to Autozone which they charged and tested and was told was bad. So I purchased a new battery and still the same problem***
Also forget to mention, just purchased this EB last month and the only key I have is spare key that was made and not one of the originals. Also I posted earlier about my radio issue as well, so I dont know if this is also causing a problem with stereo not pushing sound to four speakers, and rear dvd player not working. The factory sub seems to be the only thing putting out sound.
