PATS Key questions?
WangoZ
Glens Falls
1998 Explorer Sport
Wrong forum, sorry.
M pats help Modified 1995-2001 Explorers 2
T Carb+5.0+PATS=? Modified 1995-2001 Explorers 6
W PATS System Modified 1995-2001 Explorers 0
J could/should PATS be disabled Modified 1995-2001 Explorers 0
M 2001 Explorer Sport v6 to v8 swap PATS problem Modified 1995-2001 Explorers 15
J Pats Modified 1995-2001 Explorers 101
local7teener PATS components - Trying to troubleshoot a wicked misfire Modified 1995-2001 Explorers 1
R PATS problem after Push-Button Start... Modified 1995-2001 Explorers 0
R engine swap PATS question Modified 1995-2001 Explorers 2
Kris Guilbeaux Disableing PATS Keys perminately Modified 1995-2001 Explorers 9
L Key fob 98 ford exploree Modified 1995-2001 Explorers 1
N Key Off Draw - need electrical expert help Modified 1995-2001 Explorers 11
B Use same key in two Explorers? Modified 1995-2001 Explorers 5
H Torsion Key lowering question Modified 1995-2001 Explorers 8
P 2000 Limited 5.0 no power with key on.. Modified 1995-2001 Explorers 1
J torsion key Modified 1995-2001 Explorers 3
F Torsion Key and TT Modified 1995-2001 Explorers 4
A Torsion Key? Modified 1995-2001 Explorers 2
B torsion key bolt size? Modified 1995-2001 Explorers 2
L 1.5 Torsion key Modified 1995-2001 Explorers 11
J TT!!!!! vs torsion key Modified 1995-2001 Explorers 68
L Shock/Torsion Key Flip questions Modified 1995-2001 Explorers 3
A key flip Modified 1995-2001 Explorers 1
9 torsion key Modified 1995-2001 Explorers 2
9 99 2wd lift questions Modified 1995-2001 Explorers 1
B lowering with coilovers and other questions Modified 1995-2001 Explorers 1
Varsity 4x4 Swap Questions Modified 1995-2001 Explorers 2
L couple questions about a '98 5.0l Expo Modified 1995-2001 Explorers 11
C Lift questions Modified 1995-2001 Explorers 9
D Cooling redo and setting the 96 4.0 OHV up for some towing, got some questions... Modified 1995-2001 Explorers 10
D Body lift questions Modified 1995-2001 Explorers 3
S Exhaust leaks questions Modified 1995-2001 Explorers 17
N 98 Explorer 5.0 in 00 Ranger / Vacuum Questions Modified 1995-2001 Explorers 1
S Lifting rwd 96 questions Modified 1995-2001 Explorers 2
T Pa883 body lift questions Modified 1995-2001 Explorers 0
X Newbie - 2000 Explorer XLT 4x4 questions Modified 1995-2001 Explorers 0
F Quick & Dirty Leaf Spring Questions Modified 1995-2001 Explorers 8
C Questions about 1949 Ford F1 to Ford Explorer Frame Swap Modified 1995-2001 Explorers 48
G 2001 Explorer Sport 5.0 swap/Mustang ECU and T5 questions Modified 1995-2001 Explorers 10
D Engine swap questions. Modified 1995-2001 Explorers 4
S 98 EX, Locking Hub Questions Modified 1995-2001 Explorers 10
D '00 5.0 cam position sensor voltage questions (p0340) Modified 1995-2001 Explorers 45
S 5 speed swap questions Modified 1995-2001 Explorers 14
R Wheel figment questions Modified 1995-2001 Explorers 0
P couple questions about a '98 5.0l Expo Modified 1995-2001 Explorers 5
N Lift Questions for a 98 XLT 4WD Modified 1995-2001 Explorers 10
P 4406 swap with 4" superlift - front DS questions Modified 1995-2001 Explorers 4
M Fuel Trim Questions Modified 1995-2001 Explorers 18
S 98 explorer manual 1354 swap questions Modified 1995-2001 Explorers 1
4 Just some questions Modified 1995-2001 Explorers 0
Similar threads
