iCasper
- February 4, 2015
- Canary Islands
- 97 SOHC Explorer II, 2WD
Hello from Spain.
I located some rotted wires inside the PCM connector harness. The BK PIN 25 ground wire (attached to the firewall) was crimped already. There are two shielded wires with a foil wrap crimped to the this ground wire. It is a Y connection.
The BK ground wire PIN25 (case Ground) goes behind the engine. There is no ground to engine neither to the chassis.
I want to fix this and need to know if anyone got photos of the correct connector wiring.
Ford Explorer 1997 SOHC
