kalok85
- May 30, 2014
- 1999 Mercury Mountaineer
HI guys.......any help or advice would be amazing
A couple days ago my tuck started miss firing and a couple minutes later my PCM fuse blew out and my truck stalled.
I have 1999 mercury Mountaineer 5.0L
I traced the problem to the passenger side coil pack. Two the poles were not sparking the number 8 and 2 (paired cylinders). I bought a new coil (with a lifetime warrant thank god) and replaced all spark plugs and wires. And when I turn the key to the on position the PCM fuse blows immediately.
I can start the car with out the wiring harness plugged into the coil pack and the PCM fuse does not blow. As soon as its plugged in the fuse blows immediately
The ground wire for ignition coil wiring harness on the passenger side coil pack (same one Im having trouble with) is weak.....only reading 10v.
I don't understand why if I have a wire grounding out before the coil pack, the fuse only blows when the harness is plugged in.
Any thoughts would be awesome and if anyone know has the pinout diagram for my truck the information would be invaluable. And if no pinout diagram if someone knows the pin number for the passenger side coil pack ground wire that information would also be amazing
