scott2794
- August 29, 2013
- 2002 Ford Explorer
Need help on my 2002 ford explorer. no power to starter solenoid. Replaced stater/solenoid due to corroded wire between solenoid and starter. Still no power. Ran a jump wire to solenoid, but won't start...will turn over. I am getting power all the way to the starter relay. Swapped relays but no improvement. Odometer is reading all dashes. I tried using a code reader, but it wouldn't connect. Code reader works fine on other vehicles. Does the PCM need replaced?
