(PCV hose) Dorman universal alternative to motorcraft kcv235 ?
sullen
04 ford
Hey guys, has anyone been through this...
The motorcraft pcv hose (small one by the intake) is going for like 140$ (115 on rock auto) insane for a 6” rubber hose.
Has anyone found a dorman or similar, universal hose, that they’ve been able to make work?
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Number4
"I'm counting to 3, then I'm getting your dad."
Woodstock, GA
04 Ford Explorer 4.6l
Can you make one? Find something similar, put heat to it in order to shape it.
sullen
04 ford
Yeah probably will do that, pricing is absurd for these.
swshawaii
Kailua-Oahu, Hawaii
Since it's for emissions make sure you use a gas and ethanol resistant hose.Fuel vapors turn coolant hoses into mush in no time. What's the inner diameter?
Reusing the fittings I used Gates "Barricade" fuel injection hose to replace a deteriorating hose but it was only 3/8". The fiber reinforcement may also make it difficult to "mold" when heat is applied. Good luck.
Anyone Else Have EVAP Hose Rot?
Number4 PCV Hose Routing Stock 2002 - 2005 Explorers 2
S Part # PCV valve to Intake (Hose) Stock 2002 - 2005 Explorers 6
G PCV vent tube not hose? Stock 2002 - 2005 Explorers 5
H Latest part number and replacement for PCV hose Stock 2002 - 2005 Explorers 4
S 05 Explorer 4.0 flex engine pcv valve location Stock 2002 - 2005 Explorers 2
M Pcv valve grommet Stock 2002 - 2005 Explorers 3
L Broken Valve Cover pins for PCV Valve Stock 2002 - 2005 Explorers 5
C 2003 4.0 Vin K PCV Valve Location Stock 2002 - 2005 Explorers 2
R Replacing 2004 Ford Explorer PCV valve Stock 2002 - 2005 Explorers 1
F PCV Valve Question Stock 2002 - 2005 Explorers 5
R 2003 4.6 PCV part Stock 2002 - 2005 Explorers 5
M PCV Valve Stock 2002 - 2005 Explorers 4
A New PCV Valve - nice side effect Stock 2002 - 2005 Explorers 17
R PCV Valve Stock 2002 - 2005 Explorers 7
T Is this the PCV? Stock 2002 - 2005 Explorers 3
R PCV valve replacement Stock 2002 - 2005 Explorers 1
R 4.6 intake manifold replacement. How to tell if I have heated PCV? Stock 2002 - 2005 Explorers 9
J 02 4.0 PCV valve replacement and location Stock 2002 - 2005 Explorers 6
B PCV valve related? Stock 2002 - 2005 Explorers 0
K PCV valve location and replacement Stock 2002 - 2005 Explorers 2
R Intake Manifold/ Heated PCV Stock 2002 - 2005 Explorers 0
M general PCV/breather question Stock 2002 - 2005 Explorers 5
H Question about pcv (P1151 and p0174) Stock 2002 - 2005 Explorers 0
G PCV valve replacement help - 2004 Explorer Limited Stock 2002 - 2005 Explorers 13
J PCV..should it do this? Stock 2002 - 2005 Explorers 0
H PCV Valve on 2002 4.0L V6 Stock 2002 - 2005 Explorers 2
J PCV valve leaking oil... Stock 2002 - 2005 Explorers 1
J PCV valve location Stock 2002 - 2005 Explorers 4
X pcv valve question Stock 2002 - 2005 Explorers 1
S Valve cover (PCV hole) Stripped...What to do!? Stock 2002 - 2005 Explorers 3
C PCV valve on a 2002 4.0L SOHC. Stock 2002 - 2005 Explorers 9
2 2004 4.6L PCV system For diagram needed ASAP Stock 2002 - 2005 Explorers 5
R 02 sport PCV location Stock 2002 - 2005 Explorers 1
J PCV slot broken Stock 2002 - 2005 Explorers 3
W V8 4.6L PCV Valve with pictures (is this right?) Stock 2002 - 2005 Explorers 2
S PCV removal in 4.6L 2003 XLT Stock 2002 - 2005 Explorers 1
H How to change your 2005 V6's PCV Valve Stock 2002 - 2005 Explorers 14
V 2003 4.0 sohc pcv valve Stock 2002 - 2005 Explorers 3
N 2003 Explorer 4.6L PCV Valve Location Stock 2002 - 2005 Explorers 2
0 Where is the PCV valve '02 4.6L Stock 2002 - 2005 Explorers 2
H 05 pcv = $50?? Wtf??? Stock 2002 - 2005 Explorers 17
R Can't Find Location of PCV Valve Stock 2002 - 2005 Explorers 3
J PCV valve removal?? Stock 2002 - 2005 Explorers 4
D Replacing PCV Valve, '02 4.6L Stock 2002 - 2005 Explorers 2
T PCV Valve Stock 2002 - 2005 Explorers 3
0 where is the PCV valve? Stock 2002 - 2005 Explorers 2
0 I cannot find the PCV valve!!! for 02' XLS 2WD Stock 2002 - 2005 Explorers 21
edwx Replacing PCV valve on '03 x/xls Stock 2002 - 2005 Explorers 3
J 2005 exp 4.0 flexfuel pcv valve location ? Stock 2002 - 2005 Explorers 2
T Two questions about PCV Valve and Gas Mileage Stock 2002 - 2005 Explorers 5
Similar threads
