Bulldozer
- November 6, 2011
- Calimesa, CA
- 1993 Explorer 4x4
So I scored an old set of rancho radius arms from the junkyard, installed them according to the instructions here: http://www.therangerstation.com/tech_library/Rancho_Install_Instructions.shtml and something is very off. Both front wheels are pushed back at least an inch or so. The front driveshaft is sitting nearly all the way plunged in and the tires are rubbing the back of the wheel wells hard.
I triple checked that I lined up the front mounting holes exactly 12" back from the stock radius arms rear hole (on center). Only think I can think of is maybe the explorer and ranger frames are different and I was following ranger instructions.
Anybody that has a rancho lift, do you recall where the radius arm bracket holes were drilled, or by some chance does anybody have instructions laying around?
Thanks
Thanks
