PepBoys (Delta National) Tire Recall 265/70/17 | Ford Explorer - Ford Ranger Forums - Serious Explorations
FYI: Recall Info DEFINITY DAKOTA H/T
You are receiving this message because you have requested to be notified if there is a safety recall regarding Tires from NHTSA's Office of Defects Investigation.
NHTSA Campaign ID Number: 12T013
Synopsis:
Pep Boys is recalling certain Definity Dakota H/T tires, size P265/70R17, equipped with DOT code UTT6PA70112. Contaminated rubber may have been used in the tread compound which could result in tread separation. Tread separation can result in loss of vehicle control, increasing the risk of a vehicle crash. Pep Boys will notify owners, and dealers will replace the tires free of charge. Free mounting and balancing will also be included, as applicable. The recall is expected to begin on July 9, 2012. Owners may contact Pep Boys 1-215-430-9169. Pep Boys’ recall number is 156.
For more information for this particular recall, please go to 12T013.
Thank you,
Recalls Subscription Team
Office of Defects Investigation (ODI)
National Highway Traffic Safety Administration (NHTSA)
U.S. Department of Transportation (DOT)
NHTSA Campaign ID Number: 12T012
Synopsis:
Del-Nat Tire Corporation (Del-Nat) is recalling certain Del-Nat Delta A/S Sierradial or National A/S Commando, size 265/70R17. The affected tires have a dot code of either UTIYWHA0112 or UTIYWHD0112. Contaminated rubber may have been used in the tread compound which could result in tread separation. Tread separation can result in loss of vehicle control, increasing the risk of a vehicle crash. Del-Nat will notify owners, and dealers will replace the defective tires free of charge. Free mounting and balancing will also be included, as applicable. The recall is expected to begin on, or about, June 27, 2012. Owners may contact Del-Nat at 1-901-775-5002. Del-Nat’s recall campaign number is DN-12-0618.
For more information for this particular recall, please go to 12T012.
Thank you,
willindsay
Location
Sevierville
Sevierville,TN
94 Limited
Is this just for the H/T tires or does itt include the AT tires? I have a set of AT's on my truck and would like to avoid any problems
GRNMACHINE
IL
95 Sport 4x4
From what I read it is only in the H/T in size P265/70R17.
Here is the website for Del-Nat tires (Delta National): www.delnat.com
Looks like it is COOPER who made these tires:
NHTSA Campaign ID Number: 12T010
Synopsis:
Cooper Tire & Rubber Company (Cooper) is recalling certain Cooper brand Discoverer H/T tires, sizes LT235/85R16 and P265/70R17; Discoverer LSX, size 265/70R17; and Mastercraft Courser HTR, size LT235/85R16. Also included in this recall are tires branded as Del-Nat Delta A/S Sierradial or National A/S Commando, size 265/70R17; Pep Boys Definity Dakota H/T, size P265/70R17; and TBC Sigma Stampede Radial SUV, size P265/70R17. Contaminated rubber may have been used in the tread compound which could result in tread separation. Tread separation can result in loss of vehicle control, increasing the risk of a vehicle crash. Cooper will notify owners, and dealers will replace the tires free of charge. Free mounting and balancing will also be included, as applicable. The recall began on June 15, 2012. Owners may contact Cooper Tire & Rubber Company’s Consumer Relations Department at 1-800-854-6288. Cooper’s recall number is 156.
For more information for this particular recall, please go to 12T010.
Thank you,
