Perform a vacuum test | Ford Explorer Forums - Serious Explorations
tribal599
Bay Shore, NY
99 Mountaineer
Hello. I have a 99 mountaineer 5.0. To perform this test where at intake manifold or in the vicinity can I connect a gauge to a vacuum hose. Thanks.
I put mine on the power brake booster hose
You can use any line, in fact I tested all of mine to be sure I didn't get any bad readings. My brake booster line was very shaky on my gauge when I tested mine there. In fact I would appreciate if you posted up if yours was shaky too or not. I have a feeling I may have a leak on mine on that line because you should get a steady reading.
I tried it using the brake power booster. here is the video I posted https://www.youtube.com/watch?v=KoSrcaTJswo
