oso2324
- September 18, 2004
- Maryland
- '99 Sport
My 1999 Explorer Sport AWD has just recently had routine maintanence done at 100K miles - oil and oil filter change (dino 5W30), spark plug change (Bosch Double plats), new plug wires (Autocraft 8mm) front and rear differential fluid (synthetic) changed, power steering fluid syphoned out and replaced with new fluid, cooling system flush, new brakes and rotors (Wagner), brake lines flushed and fluid replaced. I also did a SeaFoam treatment to the oil prior to changing and did the intake through the braker booster hose. Bottom line is the vehicle has never run so smooth.
I do have a question though. I just got back from a tirty minute drive where cruise control was set at 70 mph. The tach registered a steady 2500 rpm at that speed. Is that about the right rpm's?
Also has anybody bought the Scanguage. How much does it cost and is it worth the price?
Thanks, Mike
Thanks, Mike
