Performance muffler for 99 Mounty?
dr fildo
1999 Mercury Mounaineer
I have to replace the exhaust system on my '99 Mounty. 5.0. I found a reasonably priced, direct replacement full exhaust from Rockauto, but I can't seem to find any direct fit muffler choices for a slightly more aggressive than stock sound. I don't want to remove the cats or anything other than a more aggressive muffler.
Does anyone have any info/suggestions? Is it even worth the hassle?
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
I’d take it to an independent shop and ask for a quote. Usually they can fit universal mufflers on it that aren’t a direct bolt on replacement. Worth it is going to be up to you to decide. A muffler isn’t going to make a noticeable difference in power, it’s just going to make it sound different.
shucker1
Metairie, Louisiana
98 XLT 5.0
I actually have a Gibson Cat Back system.
Slight Rumble but nothing annoying.
Minor fitment issue with tail pipe hanger and a really close fit around the spring assist rear shocks.
A Performance issues with my 1998 Explorer. Stock 1995 - 2001 Explorers 15
B Xtreme Performance 4R55E Stock 1995 - 2001 Explorers 0
koda2000 Mobil 1 Extended Performance vs Annual Protection Stock 1995 - 2001 Explorers 35
L Engine performance issue Stock 1995 - 2001 Explorers 1
N Performance enhancers ? Stock 1995 - 2001 Explorers 6
koda2000 Opinions on Mobil 1 Extended Performance Stock 1995 - 2001 Explorers 18
T Driveability issues... (engine performance) Stock 1995 - 2001 Explorers 4
P where is henson performance Stock 1995 - 2001 Explorers 4
L Offroad Performance: Sport vs Full Size Explorer Stock 1995 - 2001 Explorers 19
B Big project coming up, engine performance fixes on 1995 ford explorer XLT 2wd Stock 1995 - 2001 Explorers 5
P fuel saver ... better performance Stock 1995 - 2001 Explorers 2
T High Performance EDIS Coil Pack 1989-99 Ford & Mustang Stock 1995 - 2001 Explorers 1
M ~ Performance Parts ~ Stock 1995 - 2001 Explorers 13
K Rough Idle and performance Stock 1995 - 2001 Explorers 1
J Engine Performance Problem Stock 1995 - 2001 Explorers 3
A Performance Parts Stock 1995 - 2001 Explorers 8
D Mobil 1, do yo use Extended Performance? Stock 1995 - 2001 Explorers 9
K Performance upgrades. Help? Stock 1995 - 2001 Explorers 23
L Shift Solenoid C Performance or Stuck Off Stock 1995 - 2001 Explorers 7
M Unplugging MAF Improves Performance. Rough Idle / Hard Shifting Stock 1995 - 2001 Explorers 14
D Colder Temperature Better performance Stock 1995 - 2001 Explorers 3
D Camshaft position sensor/Performance Stock 1995 - 2001 Explorers 2
T high performance exhaust system Stock 1995 - 2001 Explorers 3
J Performance moduals or chips advice Stock 1995 - 2001 Explorers 1
J performance modifications Stock 1995 - 2001 Explorers 1
J K&N Injection Performance Kit for 97 Mountaineer Stock 1995 - 2001 Explorers 4
S Jet Performance Module 98 5.0 XLT Stock 1995 - 2001 Explorers 5
T Performance Parts for 2001-2003 Ford Explorer Sport (found these...) Stock 1995 - 2001 Explorers 2
H Recommended Performance chip for 2000 4.0L V6 SOHC Sport Stock 1995 - 2001 Explorers 19
S winter performance question?? Stock 1995 - 2001 Explorers 0
J Performance issues / backfiring loss of power Stock 1995 - 2001 Explorers 3
L performance chip suggestions Stock 1995 - 2001 Explorers 4
J Jet Performance? Stock 1995 - 2001 Explorers 9
R awd performance vs. 4wd performance.. Stock 1995 - 2001 Explorers 5
S Drive way performance exhaust Stock 1995 - 2001 Explorers 2
J Explorer 4.0 Mileage Performance Issue Stock 1995 - 2001 Explorers 2
C Better Performance? Stock 1995 - 2001 Explorers 11
G AC Performance Update Stock 1995 - 2001 Explorers 3
T Increasing Power and Performance Stock 1995 - 2001 Explorers 2
L Performance shocks help for eddie bauer explorer Stock 1995 - 2001 Explorers 10
R Error code 214 Help solve the mystery! - Intermittent CEL, Random poor performance Stock 1995 - 2001 Explorers 1
O Performance Improvements after Maintanence Stock 1995 - 2001 Explorers 6
T Muffler Stock 1995 - 2001 Explorers 3
D Help with Exhaust pipe and muffler replacement Stock 1995 - 2001 Explorers 5
R Muffler Inputs Are Different? Stock 1995 - 2001 Explorers 16
J Smoking Muffler Stock 1995 - 2001 Explorers 6
GingeRed11 Muffler upgrade Stock 1995 - 2001 Explorers 4
V Why can't I find a direct fit muffler? Stock 1995 - 2001 Explorers 3
B Best Muffler for Stock 1997 Exp. Limited 5.0 Stock 1995 - 2001 Explorers 1
C 03 Sport XLT 4.0 sohc Muffler size? Stock 1995 - 2001 Explorers 2
Similar threads
