Thanks! I've no idea if the mic was on, I just assumed with it connected through Bluetooth it would work just like all other vehicles I've utilized Bluetooth for phone. That's obviously not the case ... Like others have reported it starts a conversation just fine but then the echo and my voice comes across robotic. I'll try the private button as a temp fix in the meanwhile
Thanks! I've no idea if the mic was on, I just assumed with it connected through Bluetooth it would work just like all other vehicles I've utilized Bluetooth for phone. That's obviously not the case ... Like others have reported it starts a conversation just fine but then the echo and my voice comes across robotic. I'll try the private button as a temp fix in the meanwhile.
The privacy mode will just switch the microphone and speaker over to your cellphone.
I was able to do some testing. The microphone on the phone (and other devices like Apple Watch) are muted when connected to the Explorer's phone. There is not cross talk between microphones. Only the Explorer's mic is active.
****New Theory:
I believe the Speed-Compensated Audio is what is throwing off the system. The point of the feature is that when you are driving at 65 MPH on the highway, there is more road noise. The radio is slightly louder. Then, when you pull off on your exit and are going 20 MPH, there is less road noise. The radio will automatically adjust the volume down to compensate.
The same thing seems to be happening on phone calls. The car's speakerphone does a semi-mute when the caller is talking. When the driver is talking, it takes off that semi-mute and picks up their voice. That works fine for a while and no echo is heard. But it appears that the compensation starts to mess with the semi-mute. As you speed up and slow down, the semi-mute gets confused.
I'm going to turn off the speed-compensated audio feature for a while and see if the phone echo comes back. To do this, follow these steps:
1) With the car on (or in accessory mode) go to "Settings"
2) Make sure the radio is on (that way the sound setting can be accessed)
3) Hit the sound button in the settings menu
4) Hit the "speed-compensated audio" button
5) Turn the setting to "Off" (it is set to medium for factory default)
