Photoshop Tutorial: Add/subtract and placing an object
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
1975 Ford Bronco 4x4
I found one of section525's tutorials. :)
Use the Lasso (L) to outline the shock
Then [Select] [Feather] it.
Then [Select] [Inverse] it. Then double-click the Background layer and hit [OK] again.
Hit the [Delete[] key.
Then open up your other image (if you have one). :p
Use the Move tool (V) to drag the shock to your other image.
Then [Edit] [Transform] [Scale] the shock to whatever you like.
Booyah?
:D
Post up any questions you may have. :thumbsup:
