Photoshop Tutorial: Placing an object | Ford Explorer - Ford Ranger Forums - Serious Explorations
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
1975 Ford Bronco 4x4
I'm not quite understanding what you're wanting.. but I think it's this?
Use the Lasso (L) to outline the shock
Then [Select] [Feather] it.
Then [Select] [Inverse] it. Then double-click the Background layer and hit [OK] again.
Hit the [Delete[] key.
Then open up your other image (if you have one). :p
Use the Move tool (V) to drag the shock to your other image.
Then [Edit] [Transform] [Scale] the shock to whatever you like.
Booyah?
:D
