Pic Request- Your Explorer Towing
Maniak
Moderator-Stock 91-94
Staff member
Moderator
Vail, Arizona
1992 XLT 4x4
Here's the X parked at work.. I picked up some block on the way to work this morning to take home.. I don't think I'm taking the freeway home.. I don't want to be on the news..
Turns out block is 39lbs each.. not 29lb each.. thats a pallet of 90 on there.. you do the math..
~Mark
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
Maniak
Staff member
Moderator
Vail, Arizona
1992 XLT 4x4
The axle is 3500lbs.. trailer is officially 3000..
which is why I'm going to go through town.. 40mph or so max.. 65mph just seems like a good way to get on TV tonight.
~Mark
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
more triangulation
:p:
frickea86
Rust? You mean character!
Pittsburgh, PA
'97 XLT SOHC
Nice "loads" guys --- That is a freaking weired statement.....:confused:
Well this is mine....Trailer alone weight 1500lbs, two 500lbs quads and some wood and i'm about at my limit. Shes got brakes and hauls like a dream. Axles are rated for 8000lbs and the frame is rated for 12000lbs. So about 4 tons is our max.
2nd Picture = Trans Failure Ironic!!
FROADER
Moderator
Staff member
Moderator
Huntington Beach, CA
1997 XLT
~Mark
To quote exploderpilot from truck haven. "That's how you end up on youtube" :D
Drive safe!
manaen
Clear Spring, MD
2011 Xterra Pro-4X
Yeah youtube is one thing, saying stuff like....
Nice "loads" guys
may get in jail, and on a totally different set of websites that we will not discuss here :rolleyes:
MountaineerGreen
Towing Moderator
Moderator Emeritus
North East Arkansas
2012 F150 4x4
~Mark
If I was towing that, I'd want the pallet ~1' forward, more tongue weight. I am a big fan of tongue weight, too little and you get mega sway with heavy loads.
Maniak
Staff member
Moderator
Vail, Arizona
1992 XLT 4x4
I had the forklift guy push the pallet forward until the back of the truck dropped about about 3". I figured that was enough tongue weight. I have OME-36 springs... which have an inverse arched overload. In other words, the overload doesn't even touch the main spring (might as well not be there)..
The trailer's suspension dropped at least 3" or so also with that weight (normally the trailer sits the same height at the truck).
It towed great. its 35 miles or so from work to the house.. top speed was 55mph (stayed on surface streets). It towed straight and true.. I was really suprised..
It was 85F out and the trans pan temp averaged 160-170 through town. It peaked at 175 once when I went from a stop to 55mph. When ever I got a chance I'd lock the converter (I can manually lock it in any gear except 1st) and 3rd gear with the converter locked... 2000 rpms was about 45.
~Mark
Kris Guilbeaux
Elite Demon Secretary
Staff member
Moderator
Austin,Tx
92 Nav, 99 Mounty, 98 Ex
Same reason the About above pictured Mounty dropped so bad with a load on it. the OME springs are not the best for towing.
flyinguitars500
Grandville, MI
2002 V8 XLT
ok heres my ex.
the trailer is a custom built giant. the thing weighs a ton...the bed itself is a air tight chamber with a air fitting in the front. i will be towing a couple of cars this weekend. ill post pics later
heres the reciever
Tony Raine
Bono, AR (outside Jonesboro)
'01 Sport
this is what jumping the dirt mounds on logging roads does to a 20+ year old front axle
same spot, different occasion
Charlie
Wisconsin
2000 Limited
This isn't mine, but I saw this while driving the other day and thought about this thread. This was being towed on the freeway. I tried to get a better picture, but while I was passing them I accidentally pressed the "zoom in" button on my phone instead of the "capture" so I didn't get the picture until I was along side him.
Edit: Is this a member of the forum? Those taillights seem familiar
Tbars4
Moderator Emeritus
Elite In Memoriam
anaheim hills,california
95 ranger 4x4/ 91 X 4x4
justin146
Oxford, MS-- home of the Ole Miss Rebels
2000 XLT Sport 5.0 Turbo
no heavy towing for me; although I do have plenty of torque....
Ramius
Thüringen
Explorer 4.0 97
Here is mine.
And now the hitch after lifting.:rolleyes:
Tbars4
Moderator Emeritus
Elite In Memoriam
...:eek:...I just seen this....Ramius, Nice X...:thumbsup:
explornj
now in Raleigh,nc
99 sport 4.0 sohc
i wish i had more pics of all the trailers that i have towed with the x, too many cars to the junk yard
Champcar_Fan
No.Cali
1993 XLT 3
Here's mine towing a couple of jetskis.
GJarrett
Moderator Emeritus
Location
SC
Chief GPS'um and Still Lost Native Texan
'99 EB 4x4 "Herc" RIP
Here's my tow. Yes it's just a wee bit over the rated limit LOL. I don't pull it over 50~55 mph.
O Yes I did search ...looking for a pic Tow Rig Forum 4
I Towing Mirrors for 2015 Explorer? Tow Rig Forum 0
M Installing Neutral Tow kit in my 2010 Ford Explorer Tow Rig Forum 2
M 2010 Explorer 4.0 v6 towing capacity? 5205lb? Tow Rig Forum 6
B 2016 Explorer, no tow package HELP!! Tow Rig Forum 9
J 2018 Explorer Sport - Towing a Travel Trailer Tow Rig Forum 47
M 2006 Explorer w/tow package electrical problem Tow Rig Forum 2
D 2012 Explorer XLT adding 7-pin without factory tow package Tow Rig Forum 11
C Towing Camper w/ Explorer Sport V6 AWD Tow Rig Forum 19
skoville Wanted Need to get a Explorer unstuck. Tow Rig Forum 6
C 96 Explorer - Eddie Bauer - Trailer Harness Tow Rig Forum 1
C Using a tow dolly for 97 explorer sport Tow Rig Forum 2
4 Towing issues with lowered 5th gen Explorer? Tow Rig Forum 3
J Towing Trailer Length for an '07 Explorer Tow Rig Forum 4
S 2016 Explorer XLT - Aftermarket Tow Install Tow Rig Forum 3
V 98 Explorer loading/unloading a boat Tow Rig Forum 5
F 2013 Explorer Brake Controller Wire Harness Tow Rig Forum 1
M 2016 Explorer Sport boat/small trailer. Tow Rig Forum 7
R 2016 explorer 2.3L dealer install "factory" tow package Tow Rig Forum 1
P 2008 Explorer Class 2 towing HEIGHT problem Tow Rig Forum 3
J 1996 Explorer Trailer Wiring Tow Rig Forum 3
J 1995 Ford Explorer with no right turn signal or brake on popup camper Tow Rig Forum 0
M 2016 Explorer Brake Controller connection under dash Tow Rig Forum 9
G '03 2-door Explorer - are we being safe? Tow Rig Forum 8
E 04 Explorer 4x4 with Class II hitch Tow Rig Forum 3
L 2014 Explorer Sport and Boat Towing Tow Rig Forum 5
Number4 Loading an Explorer on a tow dolly Tow Rig Forum 3
E '03 Explorer - first time towing! Tow Rig Forum 3
C 2015 Explorer towing Tow Rig Forum 3
C Tow One Explorer With Another Explorer ? Tow Rig Forum 5
B pulling explorer out of snow Tow Rig Forum 3
W 2wd 6cylinder 2003 explorer - tow capacity Tow Rig Forum 2
M New Explorer Question Tow Rig Forum 1
B 2004 Ford Explorer - next choice ? Tow Rig Forum 2
J Trailer harness issues - 2003 Ford Explorer Sport Tow Rig Forum 0
MidnightRebel07 Who here flat tows their Explorer's, Sport Trac's, etc...? Tow Rig Forum 20
U 2009 Explorer suspension upgrade for towing? Tow Rig Forum 8
X Towing with 2011 5 th generation Explorer Tow Rig Forum 15
M Anti Rattle Hitch for 2010 Explorer Class II Hitch? Tow Rig Forum 1
E A V6 third gen explorer, some time, money, and a dream Tow Rig Forum 0
E 2002-2005 Ford Explorer Tow Hitch Bolts Tow Rig Forum 3
M '98 Explorer XLT 5.0 Trailer Wiring HELP! Tow Rig Forum 4
E 02-05 Explorer Towing Questions Tow Rig Forum 2
R UHaul and the Ford Explorer Tow Rig Forum 19
G 2013 Explorer, do I need a brake controller? Tow Rig Forum 8
E towing boat with 2 door explorer sport Tow Rig Forum 9
J 2011-2014 Explorer Tow Button Tow Rig Forum 1
J Need help deciding what to buy - explorer or 4runner Tow Rig Forum 5
K Trailer Wiring Problem on 1994 Ford Explorer Eddie Bauer Edition Tow Rig Forum 0
S 2013 Explorer Towing Noise Problem Tow Rig Forum 13
Similar threads
