Well I picked up a rebuilt 302 block today and will be building it up hopefully to be done by next spring. On Tuesday it is going to the machine shop to get bored .30 over. I have some mods planned and want to run them by to see what you guys think/suggest. My goal is to run 12's in the 1/4.
Summit Engine stroker kit. This will bring it up to a 347. It comes with cast 3.40" stroke crank, forged 4340 H-beam rods, keith black hypereuctic pistons, speed pro piston rings, clevite bearings, fel-pro gaskets and melling oil pump.
Zex 100 shot of N2O
Ford Racing E303 cam and Roller rocker arms (I see two pedestal mount heads & stud mount heads, which ones do I get).
BBK 255lph fuel pump
Ford racing 30lb/hr injectors.
Would I need anything else to make this work? Anything else I should add or not do?
Mods I have so far are Mac Intake, Pro-m 75mm mass air, underdrive pulleys, flowmaster 40 series 3" cat back exhaust.
Zex 100 shot of N2O
