2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
I need ignition controlled and light controlled power sources (12v) for my multipurpose oil gauge http://www.explorerforum.com/forums/showthread.php?t=247990 and A/F ratio meter http://www.explorerforum.com/forums/showthread.php?t=253894 to be mounted on a pillar pod. I planned to trace the wiring behind the passenger compartment fuse panel. However, when I removed the three mounting screws that mount the fuse panel and looked behind it I found a tightly bundled inaccessible wiring harness. I've read a thread on this forum that describes a method of removing a fuse, wrapping a wire around one fuse blade and then reinserting the fuse and wire. I'm looking for a more permanent solution. Can anyone help me?
