Got a lot of pinging uphill and/or with wide throttle.
As plugs and leads were probably not replaced before I bought the car at 42000mi, and now it's done 100000, I put in the Bosch Platinum 4+ plugs and a set of Bosch wires.
All old sparkplugs looked reasonable.
Mucho improvement in power and feel and engine running smoothly. Same pinging under hard conditions.
The check engine light has been rampant recently from before and after the replug.
I know I need to reset computer and check for vacuum leaks etc.
What bothers me is I would occasionally get a code saying EGR valve problem but it was very intermittent.
I read someone say the MAF sensor could need to be cleaned for pinging, I'll do that tomorrow. Someone else said EGR valve (like the computer did) problem is I can't find reference to the EGR valve in the Haynes manual.
Does a 1994 4.0L engine have EGR and if so it is operated by vacuum or electrical, where is it licvated? How do you test/replace?
Thanks Tim
Thanks Tim
