protools and jd2 use different dies. They can not be interchanged.
I know where you're going with this... I've seen guys build stuff with 2 7/8" drill stem and seen it crack or shatter with a hard lateral impact. The right pipe may do the trick, just most guys buying pipe to save bills are going to Home Depot and buying really weak structural stuff. There is tough pipe, probably cheaper than DOM tubing, but you gotta know what you're buying. It was mearly an observation, but you're point is taken.
Haha, no problem i had a point but i was joking around a bit too.
Yes, the Lowe's/Home Depot stuff is furnace welded bottom of the barrel stuff and IMHO should only be used on bumpers, sliders, etc. etc. Personally i wouldnt use it at all as from what ive seen its the same price as what my steel supplier sells which is always either USA or Canadian made A53b hrew.
