Pitman arm connector 1993 explorer 4wd | Ford Explorer Forums - Serious Explorations
Four exploder
Plymouth, ca
1993 explorer Eddie Bauer
There's some sort of ball joint from my pitman arm to the inner tie rods. I was going to order a new pitman arm, but they don't seem to have this, nor does the inner tie rod I ordered. I asked at 2 auto parts stores, and they don't seem to know the correct name for this, so I'm hoping someone reading this does.
Thanks in advance
From what I can tell they are calling it an outer tie rod, but I'm not positive. Hopefully someone else will jump in to clarify.
that part that goes from the pitman arm down to the tie rod is the center link or drag link (depending on what parts store you go to, they all call it one or the other).
