plastic welding radiator tank.....
lounge lizard
Eastern PA
1997 xlt awd
so
I have a crack in the passenger side radiator tank. just like most others have gotten.
and I have wondered if this happens because of the body lift raising the radiator and the fluid wanting to be at level with the motor.
now I know you can lower the rad. some in the body on some model explorers.
but
I brought home a plastic welding from work and I was wondering if or what type of plastic is the tanks made out of?
I have some PVC rod which can be used to weld PVC and ABS plastic.
so
I figured I would try this and see if I can repair it. if not, I just have to get a new one and put it in.
planning on that anyway! but if I can do this and save some $$ why not?
any input on this project?? ;)
colintrax
Georgia
97 XLT
Pretty sure the radiator is a thermoset plastic, which means you can't melt it. Feel free to give it a try and let us know what happens though
lounge lizard
Eastern PA
1997 xlt awd
welding tank a waste of time.....
well
after getting the radiator out of the truck. I found that there was no way to weld the tank.
the old radiator.
the hair line pressure crack is between the two middle ribs and ends at the two outer ribs.
new radiator.
lounge lizard
Eastern PA
1997 xlt awd
here is that tab on the passenger side that holds the condenser to the radiator.
the driver side condenser bracket did not want to come out. and with the temp outside at 20 - 25 degrees out it decided to break instead.
so I cut the top part of the mount that broke off. and I only used the lower part of the mount to hold the condenser from the bottom to the middle of the radiator.
lounge lizard
Eastern PA
1997 xlt awd
this just sucked
after an hour or more of just wrestling with the condenser and radiator to get them into place.
I finally had it very close to being ready to mount to the truck.
got the passenger side mounted up and all has to be done is hook up the upper hose.
made it all fit once again! :D then it was time for the final hook ups and the refill.
after 4 - 5 hours I had it all back together and filled up with antifreeze
lounge lizard
Eastern PA
1997 xlt awd
the lower radiator hose came out of the truck looking like this after being in the truck for almost a year after a body lift.
so I had to cut off about 2" of hose to give it some room.
something I will have to change out in the future to a flexible hose like I have on the upper hose. :thumbsup:
Torqueranger
99 ford explorer 5.0l
I just replaced my radiator to because of the same problem except my cracks where vertical but I had problems getting the tranny lines sealing and had to use Teflon tape...
lounge lizard
Eastern PA
1997 xlt awd
well
I got my radiator at pepboys. I know right!
but it had secondary fitting in it for the transmission lines, which made it so much easier to get them in place and to seal up.
my hard part was the condenser brackets.
there is just no room to move the radiator to the passenger side while moving the condenser to the driver side.
but after modifying the driver side condenser bracket, it was much easier then if that driver side bracket was completely in tact.
but I'm still wondering if doing the body lift had anything to do with the failure of the radiator?
I know mine was the original radiator from the factory, so it most likely needed to be replaced anyway.
lounge lizard
Eastern PA
1997 xlt awd
my old radiator is cracked vertical as well. you just can't see it in the picture.
it just runs through the ribs in the middle of the picture
J Scrap Plastic Trim? Modified 1995-2001 Explorers 3
B Plastic Trim Removal Modified 1995-2001 Explorers 7
L paint match grey plastic trim on 2nd gen? Modified 1995-2001 Explorers 2
K 00' XLT Plastic front bumper swap on 98' Modified 1995-2001 Explorers 2
C Explorer Sport Plastic Removal Modified 1995-2001 Explorers 6
S plastic bumper painting? Modified 1995-2001 Explorers 6
N Painted plastic panels on 2dr explorer.... Modified 1995-2001 Explorers 0
W What color should I get the plastic on the outside? Modified 1995-2001 Explorers 7
B Removing plastic bumper piece(pic) Modified 1995-2001 Explorers 13
xplrsport01 painting grey plastic trim Modified 1995-2001 Explorers 2
K welding wish bone frontend to a solid axle Modified 1995-2001 Explorers 0
S welding on cooling fins Modified 1995-2001 Explorers 5
M Rlc welding front bumper installed!!!! Modified 1995-2001 Explorers 35
R Just got my new bumper from RLC Welding installed!!! Modified 1995-2001 Explorers 32
D Sandersons welding Modified 1995-2001 Explorers 10
C Tools For Welding? Shaving and installations. Modified 1995-2001 Explorers 2
N Welding Question??? Modified 1995-2001 Explorers 3
W Welding 02 bung in SS exhaust Modified 1995-2001 Explorers 3
A Radiator Mod to increase ground clearance? Modified 1995-2001 Explorers 7
BUXTER RADIATOR AIR DAM Modified 1995-2001 Explorers 0
BUXTER BROWN STUFF & BLACK PARTICLE FLECKS IN RADIATOR COOLANT ? Modified 1995-2001 Explorers 16
5 5.0 aluminum radiator? Modified 1995-2001 Explorers 5
traveler Installing a new all aluminum two core radiator Modified 1995-2001 Explorers 110
9 Custom ebay aluminum radiator ?? Modified 1995-2001 Explorers 9
A See Through Radiator Hose Modified 1995-2001 Explorers 13
F All Aluminum Radiator Modified 1995-2001 Explorers 3
kythri 3-Row All Aluminum Radiator Modified 1995-2001 Explorers 11
9 Aftermarket non factory replacement radiator Modified 1995-2001 Explorers 4
T A/C not working after radiator swap Modified 1995-2001 Explorers 17
L radiator leaks verses body lift installation..... Modified 1995-2001 Explorers 1
95exploder817 new radiator with org fan shroud Modified 1995-2001 Explorers 1
T I blew the side tank off of my radiator! Modified 1995-2001 Explorers 0
G v8 Body lift radiator drop bracket problems Modified 1995-2001 Explorers 21
D radiator problems Modified 1995-2001 Explorers 0
B 5.0 Radiator in 4.0? Modified 1995-2001 Explorers 3
jwrezz New Radiator, Black Magic Extreme 180 Fan Install Modified 1995-2001 Explorers 12
Glen4X4 How many of you kept the radiator scoop? Modified 1995-2001 Explorers 17
W radiator 'rock gaurd protector' Modified 1995-2001 Explorers 1
slyfoxexplore Bad radiator leak! Modified 1995-2001 Explorers 6
C Radiator Modified 1995-2001 Explorers 2
F Winch mount/Radiator support? Modified 1995-2001 Explorers 5
P Electric Radiator Fan Conversion Modified 1995-2001 Explorers 3
W 2row vs 4 row radiator Modified 1995-2001 Explorers 6
A Braded Radiator hoses. Modified 1995-2001 Explorers 7
Similar threads
