  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
PLEASE HELP! Boggs under accelleration cyl 4 misfire code. PLEASE HELP!!!
cincydru
cincinnati, ohio
00 XLS
i have a 2000 explorer xls and it is running rough.
its throwing the P0304 cyl 4 misfire.
so far i've replaced: wires, plugs, pcv valve, pressure sensor, coil pack, and its still running rough.
i can not find out what the problem is. so far i've gathered from searches on this site is the lower intake manifold gasket? im CLUELESS..
it boggs down alot while accellerating in what seems to be 4th gear. it also boggs while going uphills under heavy accelleration.
when going around 70mph the check enging light flashes, but stays on.. it has a few other codes it throws cant remember exactly what it is right now.
has anybody else had this problem before? can anyone help with solutions! I WOULD GREATLY APPRECIATE IT!!!!!!!!!!!!
THANKS
team
i would do a compression test and or a leak down test on that cylinder before buying more parts
cincydru
cincinnati, ohio
00 XLS
any more suggestions?
corkey
Moderator Emeritus
Moderator Emeritus
Location
Sioux Narrows Canada
Elite Canuck,multiple ifs offender,, and musky maniac,, i wheel and i fish,,
99 xls,96 xl,91,08 Ranger
a compression test,, why , we want the codes from the computer first,, they telll ypu what it is doing , and why,,
so, before you throw a whole bunch of money , and parts at it,, get the codes from the computer ,. and we will try to help you ,
team
So he can know the condition of that cylinder, that's why. He already knows only one cylinder is misfiring (because of the magical code he has) and he has pretty much replaced the entire ignition system. So besides swapping injectors around (which would take more time than a compression or leakdown test on that cylinder) I would do a compression or leak down test.
And yes, he can still get the codes read also.
98mountaineerX
trenton michigan
1998 mountaineer 5.0
Im having the same problem on my 98 mountaineer i replaced my plugs and fuel filter so far but another code im getting also is a P0153 sensor cuircit slow (bank 2 sensor 1), i was told that it can be the 02 sensor or it could be a bad mass air flow sensor, i cleaned the mass airflow and its still doing it, so i guess it could be bad all togather or it could be the 02 sensor guess ill have to trial and error it. any 1 know a good cheap parts place online? :(
bryanhbre
Elkhart, IN
2001 mountaineer
I think you can unplug the mass air flow sensor & it'll throw the thing into "dummy" mode. If it runs better it could be the MAF but from personal experience, there are so many sensors that are all inter-connected that the MAF may not end up being the problem anyway. I would do a compression test too as the others have suggested, I'm not too sure about how the error codes work with individual cylinders but it may also be a bad catalytic converter if it's really bad under acceleration or going uphill. (I wouldn't think a bad cat would throw a misfire code in one cylinder but who knows)
BlkExplorerSport
Saskatchewan
'99 Explorer Sport
you may not think it could be from something so little, but try new spark plugs.
robertoa1a
Jacksonville, FL
96 5.0 xlt 2wd white/char
At night I could see a big spark shooting from the wire straight to the head every few revs on my girlfriends. It was a crack in the wire boot insulation.
98mountaineerX
trenton michigan
if i had a bad spark plug wire wouldnt it shock me if i grabbed it while it was running cause i tried that lol yeah im a dumbass lol
chapsdeva
Richmond, Va
2015 Limited
It could very well be a cracked plug. I had an 81 Honda that had identical symtems as you have and the plug was cracked. Try replacing the #4 plug and see if it helps.
98mountaineerX
trenton michigan
just changed all the plugs this last weekend and still doing it thanks tho im going to ake off all the air intake shit and see if theres a messed up vaccume line or something on it then if not i guess ill go and buy the 02 sensor
cincydru
cincinnati, ohio
00 XLS
after a few clicks from an army website (since im in the army i have access to).. i found anything and everything including ALL CODES my truck could possibly throw...
and its coming down to the
Trouble Code: P0304 (4.0L V6 VIN E Auto)
Cylinder Number 4 Misfire Detected Print this code data
Number of Trips to Set Code: 2
OBD II Monitor Type: CCM Details
Indicators: MIL Details
■MISFIRE Details
■MIL Details
Trouble Code Conditions:
DTC P0136, P0156, P0171, P0172, P0175, P1130 and P1150 not set, engine started, engine running under positive torque conditions, and the PCM detected a misfire a misfire in Cylinder 4 during the 200 revolution (Catalyst) or 1000 revolution (High Emissions
Possible Causes:
■Air leak in the intake manifold, or in the EGR or PCM system
■Base engine mechanical problem that affects only Cylinder 4
■Fuel delivery component problem that affects only Cylinder 4 (i.e., a contaminated, dirty or sticking fuel injector)
■Ign
and
■MISFIRE Details
■MIL Details
Possible Causes:
■Ign
both have "intake manifold" listed... im beginning to think its the gaskets or a line thats rotted somewhere... can anyone point me to the rubber hoses that they might think is the problems that may be common to go bad often or something? i have a feeling this is an easy fix (prays crosses fingers)
BTW, this is chiltonlibrary.com i have access to :) i also have access to automotive repair reference center.. i just found this out LOL....
i hope someone on this board can point me to the hoses i should check to see if their cracked etc... thanks again for everyones help.. ill keep you updated!
BTW - I WILL WITHIN THE NEXT FEW DAYS GO GET THE CEL CODES SCANNED FOR YALL!!
D Please help with posting a picture of your 1995 Explorer XLT Power Distribution Box Stock 1995 - 2001 Explorers 8
G Spare part ordering issue? Please help.. Stock 1995 - 2001 Explorers 23
V 1999 XLT Problems...Please Help Stock 1995 - 2001 Explorers 8
M Radio with no sound 95 explorer please help Stock 1995 - 2001 Explorers 2
9 Exhaust pipe STUCK! What a PITA! Need help please... Stock 1995 - 2001 Explorers 15
S Help Please! Valve cover wont come off Stock 1995 - 2001 Explorers 2
donalds trans pan gasket help please Stock 1995 - 2001 Explorers 25
B 2001 Ford Explorer Sport. New MEMBER. HELP PLEASE! Stock 1995 - 2001 Explorers 10
M Need Some Help Please Stock 1995 - 2001 Explorers 3
P Solved 98 xlt crank no start. Please help Stock 1995 - 2001 Explorers 11
R Need some help please Stock 1995 - 2001 Explorers 4
D PLEASE HELP HAVE SPARK AND FUEL YET STILL NO START ON MY 1998 EXPLORER 4.0 Stock 1995 - 2001 Explorers 13
R Please help!!! Stock 1995 - 2001 Explorers 4
R Exhaust issues, please help Stock 1995 - 2001 Explorers 11
H PLEASE HELP ME Stock 1995 - 2001 Explorers 10
D Oil gauge help please. What is normal ? Stock 1995 - 2001 Explorers 6
3 Please help, leaf spring bushing. Stock 1995 - 2001 Explorers 7
L Multiple DTCs need help please! Stock 1995 - 2001 Explorers 1
B Please help fast Stock 1995 - 2001 Explorers 5
9 Someone please help my window and seat switches quit working. Stock 1995 - 2001 Explorers 2
T 99 explorer sport please Help!! Can't figure this thing out Stock 1995 - 2001 Explorers 18
K Please help me identify this plug Stock 1995 - 2001 Explorers 4
O V Reg Explorer help please - PAS pipes Stock 1995 - 2001 Explorers 2
K 98 Explorer 4.0 OHV Can't find the misfire! PLEASE HELP! Stock 1995 - 2001 Explorers 16
E Idle issue, with no codes. Help please Stock 1995 - 2001 Explorers 15
R Some kind of missfire please help Stock 1995 - 2001 Explorers 10
W CEL with code P0102 and already replaced MAF. Please help Stock 1995 - 2001 Explorers 2
Whitfield Explorer XLT 2000 with issues - help please Stock 1995 - 2001 Explorers 42
J 4 Low Help Please Stock 1995 - 2001 Explorers 2
K Intake leak please help running out of options Stock 1995 - 2001 Explorers 38
H 95 Explorer 4.0l missing & stalling severely, Help please Anyone! Stock 1995 - 2001 Explorers 3
M HELP - PLEASE - fuel line quick disconnect when tool won't disconnect? ?? Stock 1995 - 2001 Explorers 5
A NO HEAT BELOW FREEZING OUTSIDE PLEASE HELP!!!! Stock 1995 - 2001 Explorers 3
B help please Stock 1995 - 2001 Explorers 1
C 2001 explorer starts and dies. Need help please Stock 1995 - 2001 Explorers 32
C Throttle body/cable help.. asap please Stock 1995 - 2001 Explorers 0
S Rounded Bottom Tensioner Pully Bolt 5.0 Please Help Stock 1995 - 2001 Explorers 6
C Rear glass hinges-- 1999 mountaineer please help Stock 1995 - 2001 Explorers 6
S No Start Please Help 4.0 OHV Stock 1995 - 2001 Explorers 3
S EGR problems, possibly pcm? Please help Stock 1995 - 2001 Explorers 3
F Misfire Cylinder 1, running lean, low compression. PLEASE HELP! Stock 1995 - 2001 Explorers 2
S '98 Limited 5.0 overheating mystery...Help, please... Stock 1995 - 2001 Explorers 3
N Arc help please Stock 1995 - 2001 Explorers 3
J Please someone help with misfire/popping Stock 1995 - 2001 Explorers 6
M Please Help. Stock alarm on 1996 randomly goes off Stock 1995 - 2001 Explorers 7
H please help - transmission trouble? Stock 1995 - 2001 Explorers 4
H HELP Please!!!!! '98 4.0 SOV warm start issues Stock 1995 - 2001 Explorers 10
E [98 Explorer XLT 5.0] (Another) Turn Signal Problem, Replaced Everything, Please Help Stock 1995 - 2001 Explorers 2
T 2000 eb explorer 5.0 awd please help Stock 1995 - 2001 Explorers 2
R 1999 Mercury Mountaineer p0171 code please help Stock 1995 - 2001 Explorers 9
Similar threads
