nmpfeiff
- April 17, 2009
- Advance, NC
- 2002 Eddie Bauer
I am fairly new to CB radios so I have a question about my radio and antenna setup. Everything seems to be working fine but I really do not know how good one should work. I am going to give you guys some details of my setup and see what you think.
I have a Cobra 29 LTD Classic mounted to the side of the center consul with Velcro. I have the coax running under the seat throwing the back door to my antenna. I have a ground wire running from a bolt under the seat to a screw on the side of the radio.
I have a 3' fiberglass antenna made by diesel electronics that I got from a truck stop. I have the antenna mounted with the clamp that came with it to the stock roof rack that is made out of plastic. I know the roof rack is not grounded but I do not know if that leads to the problem below.
The problem is I can't get the swr meter built in on my radio to get below 3. I have tried running a ground wire from the mounting bracket to the same bolt I grounded the radio but that made the swr worse.
Has anybody got any ideas since I have tried many different things. Do I need to ground the antenna? Right now I have the ground wire off and I can't tell a difference. I think this may just be a problem with the built in meter on the radio.
Sorry for the long post but i want to make sure I put in all the details.
