George W
- March 25, 2009
- NH
- 2002 Ford Ranger Edge 4X4
Hello,
I need some in general info on ATF. Is Mercon Clear colored ATF the same as Dexron-III? I'm asking this because I have a qt of DEXRON-III/MERCON that is red in color and smells completely different then the fluid I have in the TC and power steering , Clear in color and smells more like oil, or should I say looks and smell just like pre 2004 Mopar power steering fluid I have a qt of. This would be used in a 2002 Ford Ranger transfer case we just picked up. . I have tons of Mopar fluids on hand and some Napa stuff too.. The biggest issue I'm having is with the color and smell of the two.. I have no drain plug on the TC and want to make sure they would be compatible.. The manual said in it that MERCON and MERCON V are not compatible and MERCON V should not be used.. What should I use. I'm leaning to the Napa Premium/ ATF DEXRON-III/MERCON fluid I have to top the TC off with.. Should this be done? Thanks! George
