SportTrack05
- June 27, 2016
- 2005 sport trac
Hello. Just introducing myself, I have a 2005 sport trac that has been great to me for the past 2 years. It has 189xxx miles and has been used primarily as my tow/ daily vehicle.
As of a couple of months ago the fuel gauge would bounce around and just die below the E mark with the LOW FUEL being displayed on the message center. At the same time i would loose the gauge i would loose the map lights (noticed one day stopped looking for something) and when the map lights would work so would the gauge.
Ive changed/ Replaced:
Checked fuse #25 (dome lights still work perfect)
Cluster (tach and speedo started acting up a month after the fuel gauge stopped reading) 60k like new working unit
Fuel pump assembly Twice
First time was with ebay brand second time with brand new motorcraft (changed it the second time cause i thought the ebay brand might not have been compatible with gauge and just wanted to eliminate doubt)
I went through all connectors and checked to see if they are loose and or corroded. (nothing found bad or damaged)
I back fed the map lights jumping it with the dome light wire next to it and i had map lights and never blew the fuse.
I have a feeling that the power source for the map lights and fuel gauge come from or ground to the same place. I need a diagram to be able to find out whats going on. I talked to a buddy at ford and he told me that i might be the smart junction box. I want to test before i fork out anymore money as I'm already $500+ into this ordeal.
Sorry for the long post, and thank you.
-B
-B
