Mojo1966
- June 20, 2017
- Falling Waters
- 2002 Ford Explorer 4x4
I have an 2002 explorer with the 4.0, automatic, 4x4 and recently I had to change the motor. After the motor change I got it to start and it would stall out, I unhook the Maf senser and it stays running, runs like crap but it stays running. I also found I have no vac to the brakes and heater controls. I found there is a vac hose unhooked and cant found where to hook it up to. If you are standing in front of car facing motor this vac hose is near the throatle body, as you know the Throattle body sets sideway on the intake so this vac hose is just I guess you would say the back side of the throttle body rate under idle air control and this hose is about three quarters of an inch around on the outside. can anyone tell me where this hose hooks to.
