Jon Kanieski
- July 24, 2016
- Greenfield indiana
- 1995 ford explorer
I have a 95 explorer xlt 4x4 4.0 ohv my truck has developed a rough idle hasnt stalled or died yet but close. It sounds like a poppimg in the exhaust iratic rpms while driving and it surges. Im at my wits end throwing parts n money into it. It seems worse when outside temps or humidity are really high, some trips its fine others it runs terrible the whole trip????
Ive replaced both O2 sensors ahead of cat
New dpfe sensor
New egr vaccum solenoid
New egr valve n tube
Plugs n wires are less then 5 months old
Replaced both coolant temp sensors
New iac valve
New tps
Cleaned mass air sensor didnt make a difference.
Cleaned throttle body n intake best i could no change.
Replaced coil with accel coil prior to current issue (s) ive since bought a new autozone coil still the same (i didnt change the gap when i installed the accel coil could i haave burned up a plug or two??
All thats left is new mass air sensor, or crank sensor, or camshaft sensor?? Possibly fuel pump goin out?
I forgot to mention the surging and or kicking/buckin while over 35+ mph with or without cruise. I think once i might have seen a puff of smoke from the exhaust but not sure. Dont have any helpers to crank while i look.
Any ideas comments suggestion???
I do not have a voltemeter so im limited on testing....and fyi my ex left the truck sitting for a year!!!!
Thanks
New dpfe sensor
New iac valve
New tps
Thanks
